Cam Choice
70wayfarer
new zealand
hi all,
have powerdyne bd11a on a 360la motor. i hear that superchargers like more cam lsa around 114. is that correct. 360 has comp xe268h at the moment which i think has a lot less lsa.
so is there a cam out there like the 292/509 purple shaft that will work better. i would be limited to no more lift than the 509.
cheers
hi all,
cheers
camquest6 download at compcams.com
A few years back,Mopar Performance did start grinding cams on a wider centerline.IIRC,the .509 was one.Can't remember if 112,or 114.As a general rule,superchargers do like wider lobe centers.Contact your favorite cam grinder,or email the supercharger company for cam specs.
