I'm putting together a 5.9 Magnum, stock bottom end, rebuilt.
I sent the factory roller hyd cam off for a regrind and I am now validating the specs with the degree wheel and dial indicator. I'm using the intake center line method outlined in one of the Mopar small block books and referenced else where online. Heads are OFF the engine.
I'm afraid the cam was not ground to the specs on the cam card and I need some input from you gurus before I call up the cam shop and make myself sound like an idiot.
I'm locating TDC with the dial indicator on top of the #1 piston and I feel pretty comfortable I'm nailing it on the bulls eye. I triple check everything. The spec indicates a 108 center line on the intake, 116 on the exhaust. I'm finding center line by measuring with the roller lifter in place, dial indicator on the biggest/flatest surface I can find on the lifter and bringing it up to 0.050 before it hits max lift, recording the number on the degree wheel, then going 0.050 after max lift, recording the number, add the two numbers then divide by two. The interesting part is when measuring the intake center line I'm getting a consistent 116. So I measure the exhaust lobe center line. Guess what? 108. The numbers are inverted. And yes I know intake is the second lifter from the front of the engine on the #1 cylinder...unless I'm doing all of this work in a parallel and backwards universe.
So I went on to #3 cylinder and repeat the exercise. Same results, center line numbers are backwards. Lobe lift is correct at .332 on the 4 lobes I've measured so that part lines up with whats on the cam card.
Is there any other variable in my setup that could be producing these numbers? I'm using a new Coyes double chain, lining it up dot-to-dot but it does support +/- 4 degrees in either direction. I removed and reinstalled the timing chain set thinking maybe I was off a tooth in one direction or the other but I'm getting the same results. I've double and triple checked TDC. Could it just be that the cam grinder punched there number's in wrong when they were setting up the machine to grind this thing? Thanks for any input folks.
