rustytoolss
I've been looking at some small duration cams for my 273. I've got a question for those of you that know LOTS about this kind of thing. I'm listing 3 cams, and want to know if there is enough of a difference between them that REALLY makes much, if any difference for under 5000 rpm
Summit K6900
LSA 112*
Duration @.050 204/214
Lift .421/.444
Comp XE 20-220-3 (XE250H)
LSA 110* should I worry about fast ramps with stamped rockers, with cam this small
Duration @.050 206/216
Lift .432/.444
Isky 256/262
LSA 110*
Duration @.050 202/208
Lift .425/.435
Also I would like to use my stock valves (302 heads built by replacement cylinder head service) STOCK rebuilt heads. OMG did he just say " Stock 318 valve springs " ?.....yes I did.
But these are two separate questions. Cam differences first
Mine you its a cruiser driver probably never see 4800 rpm.
Summit K6900
LSA 112*
Lift .421/.444
Lift .432/.444
Isky 256/262
LSA 110*
Lift .425/.435
