silvadful
i have a eagle cam he1423al that i got with some other parts i bought.guy got it of said it a good mild street cam. only just managed to find some info on it but i dont understand which numbers to go for. its going in a
318 +.020
kb 399 piston + 6cc dome (also unsure if to zero deck these or not)
360 heads mild porting just to remove casting etc 75cc chamber (cast # 4027596)
360 exh manifold for now unless i find some cheap headers before it done
stock 360 inlet i think dual plane?(cast # 3814038)
numbers for cam are
1.6 valve lift int 501 exh 538 (trying to find out if 1.5 or 1.6)
1.5 valve lift 1nt 470 exh 504
@.50 tappet lift int 214 exh 223
lobe sep 112
rpm 1200-4900
just going to be a street wknd cruizer/almost daily driver. will get gear ratios etc next time @ car.
any help muchly appreciated
318 +.020
numbers for cam are
lobe sep 112
rpm 1200-4900
