Cam question
6T9 GTS
Blue Springs, MO
Has anyone here ever used or is running the Comp XE 275 HL cam? This is the cam that comp recomended for my 416 and I was wondering how it performs. Specs are .525" int/ext. lift, 231 exh./237 int. duration @ .050 (287 ext./275 int. advertized duration), on a 110 lsa.
Call Jim at Racer Brown and get the right cam....1-410-866-7660 after 2PM est
That's an off the shelf cam, you've got a custom motor, get a custom cam.
I used a solid comp in my buddies 340. All I remember is it was .525 lift and 292 advertised duration. I forgot the rest of the specs but it worked good in his car. Ron
Yes I have one in my 340. Vaccum went from 4.5" to 10" with this change. Old cam was 284/.484 Mopar Hyd. I have 1.6 cranes and true lift is .545. I like it fine. Good off of idle and pulls to over 6500. Good street maners also. Terry.
Thanks for all the input guys. I'm picking the engine up the first weekend in Feb.. I've been waiting all summer for this!
"Hey Cuda66273 I Love the car in your Pic,"Can You Tell Us a Little Bit About it? Like Does it Still run a 318 & What Type of Heads & Cam etc if you can,If Not I Understand.(Racers Secrets LOL)."Hey 6T9 Nice shot of the Dart Skidding Up Cant wait tell you put the 400 plus Cubes in" :thumblef:
