Interesting. "Dwayne, I think you commented on the effects of total overlap, ( in another forum) is independent of engine size pretty much?"That is the bottom line hear. I want as stout a piece as i can build for my sons' Duster, but the off idle driving experience takes presence. Dwayne, I think you commented on the effects of total overlap, ( in another forum) is independent of engine size pretty much? So i am hoping to end up with a cam that can walk away from a stop sign with 3.73 gears and allow clutch engagement by about 1500 rpm without bad manners.
Isn't overlap having a proportional effect on cylinder fill? It would seem to me, that a larger cubic inch engine, or long stroke combination would need a proper "window" to fill the cylinder effectively, especially with a flat tappet's lobe limitation. Perhaps the roller profiles help get more efficiency out of a shorter duration due to their higher @.200" duration.
It would be interesting to get an education in the science behind the "short (or, reasonable) duration hypothesis." The information would make for a great thread!
