Hi Folks
Here it is....
1971 Demon 340 Automatic (mild shift kit) with P/S and P/B
Engine is .040 over with a stock steel crank.
Heads are O heads with 2.02's and are 68 cc's (fresh from the shop)
273 Adjustable rockers with hydraulic lifters.
1969 HP Manifolds
Factory Intake and T/Q
Using reduced compression height pistons to reduce detonation (.002 into the chamber)
Static compression calculates to 9.17:1 with .040 gasket.
Quench is impossible.
Plan on using a 2400 stall with 3.23 gears
Looking for a punchy cruiser that will never see the track.
I have 2 cams in my possession and am not sure which would be best for my application.
#1. Comp Cams XE262H. With the valve timing events puts me at 7.71 Dynamic
#2 Lunati Voo Doo 268. With the valve timing events putting me at 7.86 Dymanic.
What say you all? pro's/Cons?
Thanks
Here it is....
1969 HP Manifolds
Thanks
