camber bolt torque specs?
mrhollywood
Virginia
Anyone know how much I should torque down the camber bolts in the upper control arm bushings? I can't find it in my service manual.
Should you use the normal nut and lock washer or upgrade to a lock nut. Tks.
Hope its ok if I hijack the thread for a question or two. Do camber bolts come stock? Can you get a decent amount of camber with them? Do people use offset bushings instead of camber bolts or can you use both?
Camber bolts are how these cars come. To get them to modern alignment specs you need the offset bushings or what I did and get tubular upper control arms from Firm Feel or similar products that have the extra adjustment built in and regular bushings.
Thanks!
