skrews
Would also like to see some flow #s and port pics.
Or just start a “what cam” thread. Likely your best bet if all you want is to know, without learning!Me? I want to learn....because.....I want to know about these things. mondello.com - Camshaft Theory
The Hughes cam mentioned in the article was ground by Bullet at that time. Hughes cams are now ground by Howards, a step back IMO.
I don’t “know” one way or another...... but I was under the impression the older Hughes cams were done by Engle(and this appears to be common knowledge).
And they are now done by Howards(also seems that be common knowledge).
You’re saying there was some point in between Engle and Howard’s where the Hughes cams were from Bullet?
Looking at the Bullet master list, I don’t see anything that matches up with the specs in that article.
To add to mystery when I talked to howards about the hughes grinds he said hughes sends them the masters and they just grind them, he made it clear they are not howards grinds but was nice enough to give me all the timing specs.
According to howards they are not based on existing howards lobes and they grind them per hughes requested specs. He actually compared a couple similar lobes they have at multiple lift points and the hughes are a touch faster. So, did the handful of redesigned/fast rate of lift chrysler cams from howards come before or after they started grinding cams for hughes?, and who initially came up with the timing events for the hughes lobes? idk. Only thing he said for sure was the hughes cam profiles are specific to them and are not howards lobes.From what I'm seeing the Howards lobes are used on Hughes cams, but they don't share the same duration splits or lobe separations in their respective shelf cams that use the same lobe profile. IE Hughes cams aren't reboxed Howards shelf cams.
I understand and I actually agree with you but I'm just repeating what was told to me by the tech at howards. I have looked at the master list a bunch of times and that's why I called them in the first place was to ask about those profiles vs hughes. It was funny because the tech seemed on the offensive at first like it may be a warranty and they wanted no part of it (I was calling about the specs for hughes grind I have and mentioned the core) and he mentioned that the cores are sent to them by hughes and are not the ones they use for their cams.Not trying to say what you were told isn't true. Howards does use a Landis LT1VE CNC cam grinder which makes grinding unique lobe profiles much easier than grinding cams manually on a Berco with actual physical masters. But I find it highly unlikely given the evidence I'm looking at.
After studying the majority of the Hughes cams, I can find the corresponding lobe in the Howards FM .904 lobe list. It looks like Hughes just rounds the Howards lobe up to the next .001 of an inch from what I'm seeing. If Howards has a .5876 lift lobe Hughes calls it a .588. Again not saying what you were told isn't true, but if there is a legit difference it is virtually nothing.
Btw did you ever notice that the howards master list has some Harold Brookshire cams?Not trying to say what you were told isn't true. Howards does use a Landis LT1VE CNC cam grinder which makes grinding unique lobe profiles much easier than grinding cams manually on a Berco with actual physical masters. But I find it highly unlikely given the evidence I'm looking at.
My “opinion” on the stories from Howard’s with regards to the Hughes cams is....... it’s politics.
They don’t want to just come out and say they can grind you the exact same cam you can get from Hughes........as a courtesy to Hughes.
Doesn't surprise me. A number of companies use Harold's grinds. He was a sharp cookie.Btw did you ever notice that the howards master list has some Harold Brookshire cams?
