A kool tip with por 15 is to drill 2 holes in the lid and put sheet metal screws in. Then you can unscrew them and use a small amount and put the screws back in. Otherwise its pretty much a 1 time use can as the lid seals on permenantly.
wet/dry vacuum? The second step does not get rinsed and is mostly for smooth (not rusted) metal the way I see it. If you have clean dry surface rust (no scale) you have the perfect environment for the por15 rust encapsulation. I wouldn't use the metal prep on that but I think you can if you want too.Yeah, I'll either wear an organic filter or borrow a buddie's fresh air hood. I'm still reading about this stuff, but I'm wondering how you rinse the two prep steps inside a trunk or floor pan with only surface rust / no drain holes.
Great idea. Use steel roofing screws with rubber gasket. I read where on person put a screw in the lid and one on the side at the very bottom. When it quits pouring he opens the top screw to give it a little puff of air for more pouring.A kool tip with por 15 is to drill 2 holes in the lid and put sheet metal screws in. Then you can unscrew them and use a small amount and put the screws back in. Otherwise its pretty much a 1 time use can as the lid seals on permenantly.
I think that would work well. It lays down real well with the fiberglass. Shouldn't need any weight. If you want to top coat it wait until it's just a little tacky. Its pretty benign stuff. I think you can coat it with about anything.Yeah, a shop vac would keep up with a rinse. I'll remember the screw idea. I love simple! I read on the web site to use saran wrap under the lid and wondered if that would work to keep the fiberglass cloth down in depression areas with a little weight on top while the liquid sets up. Maybe not.
This is good info. I'm going back to search for por-15 to see what else I can learn while I'm waiting for the owner of the car I'd like to buy. My mind races with thoughts of applications; undercarriage, inside doors, and?I think that would work well. It lays down real well with the fiberglass. Shouldn't need any weight. If you want to top coat it wait until it's just a little tacky. Its pretty benign stuff. I think you can coat it with about anything.
