Brendan Moroney
Aside from one of the places that will repair of the current fuel guage in a 68 barracuda has anyone used the guts of another year mopar guage? I don't know if any other cluster uses a guage that has the internal 12 to 5v regulator or not. Not sure if the guage itself steps the voltage down after the fuel needle movement or after it then to the temp and oil pressure gauges.
if there is another guage that I can swap in and put in without even the regulator I could adapt and make another regulator for the remaining gauges if I isolate the post that goes to that trace on the board.
I know that there are a couple of places reproducing the rallye gauges but they make you buy all 4 at a cost of 400$ plus. I just need the guage or if anyone here has a known working original guage with functional regulator in it I would consider that as well.
