mopar head
OK long enough, spill the beans
I couldn't have said it better myself!I think it will be used to put the wiggling pin into the wobbling shaft.
Gonna go out on a limb and point out my guess hasn't been shot down yet... until 1..2..3..
No idea. But whatever it is, it looks very professional.
You are obviously very proud of him.
It has nothing to do with lifter bores. He already has that fixture as I said they are $1600wasnt it already revealed as a lifter bore jig ?
Oh no...here we go again...I gotsta know!
Waiting patiently... I understand this is going to take a while because of all the other work that is probably happening. Did he machine the thumb wheels that adjust the height, too? That is some pretty fabrication.
Easy turning for heavy weight.
DING DING DING DING. You got it. And yes it will eventually be going on the series II after we make the riser. Common rail Cummins heads are heavy as are Cat and Detroit.Using a pilot level in the guide and adusting it accurately and holding it is critical. The first set in are 6.2 Hemi heads. He uses CBN cutters for surfacing. The finish is like chrome. As nice as my new bumpers.probably some fixture to be able to set cylinder heads in too for milling guide, seat, valve spring pocket work, etc. Is that going on the series two Bridgeport or the cnc bed mill?
If you aren’t making a mess, ain’t any work happening. I usually look like I’ve been wrestling a beat after doing something as simple as detailing a vehicle anymore. Or at least I feel like it, this getting old business is way overrated!
