Can I flush out an aluminum radiator with vinegar or some other chemical?
RockinRobin
Corsicana, Tx
The aluminum radiator on my drag car is 11 years old. It is currently out of the car. I have a kit to flush out a tankless water heater that involves using a 5 gallon bucket a submersible pump and vinegar. I was wondering if I could use this kit to flush out my radiator. Since it recirculates I can leave it running as long as I want. Is there another chemical that would be better than vinegar?
I don't know the answer, but I do have a suggestion. Try calling Griffin Radiators. I have one of their stock radiators in my 69 Barracuda, and their customer service is great. I bet they would be glad to answer your question as to how to best flesh out an aluminum radiator.
You can flush it with whatever you like for as long as you like. The question really is will it work for what you’re trying to accomplish? So, what are you trying to accomplish?
I think it might be getting clogged up a little over the years with rust from the block. Tracks now require you to run only water in the cooling system and I've noticed the car heats up a little faster than it used to.
Back in the day, we used to put some of this in the radiator and drive around for a few days, it is slightly acidic and did an excellent job flushing the radiator. We were always broke, and had to use whatever we could. I think we read about it in a popular mechanics or an old hotrod mag.
Thermocure, amazing stuff. I have used on several cars. The container says not acid or base. PH 6.1
Vinegar will eat your radiator for lunch.
THERMOCURE Cooling System Rust Remover & Flush | CRC
I'm not disagreeing, I am just asking a question. Vinegar certainly is an acid. Acetic acid diluted to 5% to be exact. But I wonder if it would really destroy an aluminum radiator if it was used for a flush. When I flush a radiator, I run it with the flushing stuff (Blue Devil Radiator flush is good, and the bottle says safe for Aluminum Radiators) in it for about 10 minutes and then drain the cooling system, flush with water and then fill up with 50/50 anti-freeze and water mixture. I don't see how some vinegar can destroy the radiator if it is only in the cooling system for a few minutes and then flushed with water.
Just use thermocure, it's really amazing. It says to drive with it in and use for several days.
How long does blue devil say to leave it in?
I doubt 10 minutes of vinegar will hurt aluminum rad, but is it long enough to help anything?
I will certainly try the Thermocure. When a fellow Mopar car guy says a product is amazing, I will try it. The Blue Devil saus to run it for ten minutes after reaching operating temperature.
I will try the Thermocure, but it looks like I'll have to wait until I get the motor back in the car and running.
When I anodized gun parts, we used lye first and it bubbled and fizzed and stank and corroded the aluminum immediately so they looked like hell, but it got rid of all the crap on the surface.
Then we used nitric acid bath and the corrosion immediately fell off and the part was instantly spotless. It was neat as hell to watch.
You could do something similar but if you had a spot that was slow to circulate, it could eat a hole there I'm sure.
I watched the video on Thermocure before I bought it. They also showed how you could drain the radiator into a bucket and reuse that water mixed with thermocure in another engine as well, or use the drain water to clean parts.
I can vouch for "Them-o-Cure" working as claimed.
It was the only thing to work on my Dakota- infamous for cooling system rust and sludge.
No, it's not.
I tried CLR 2 times and it did nothing.
Therm-o-Cure did it the first time.
Can I use Thermo cure on my brass shower head or slow draining toilet with cast iron drain lines?
Asking for a friend.
Thermocure is designed for cleaning engines, largely through driving the car for several hours to allow the heat of the coolant to react with the coolant to remove the rust. I'm sure people try all sorts of things but you're better off using a product that is designed for shower heads & toilets. Repeated exposure to that hot solution is what does it. By the way, if you have really hard water and the toilets have been there for quite awhile you may need to replace them. Our water here is really hard and all our toilets started not flushing well. I replaced one toilet and when I turned it upside down found the minerals had reduced the diameter of the poop tube to just a fraction of new. Had to replace all our toilets to resolve. No quick "pour through" fix would have helped.
I added a few gallons of vinegar to an older Honda car I bought, mixed it about 50/50 with distilled water.
Started the car up, let the engine warm up, and let it sit for a day.
Did the same procedure every day for a week.
It really cleaned the engine and radiator up, no damage.
I have done similar flushes with vinegar with good success.
