Yes, you can, but it'll suck.
Unbolt the engine mounts, hoist the engine up as high as you can, and remove the mounts all togther, then you can remove the oil pan and get to the pump.
When you raise the engine up, you'll also need to remove all attaching wires and the distrbutor cap.
