AValiant69
Member
I am currently swapping the manual 9" front drum brakes off my 69 Valiant with disks from a 78 Volare. I also bought the master cylinder, booster & prop. valve from the Volare but the booster wont bolt in without doing some cutting/drilling, is it worth it to swap them? Can I keep the M/C I have and just swap the prop. valve or do I need the newer M/C for some reason? Are their any boosters that will bolt on?
