can it be done
rsaun191
ct
Does anyone know if a headliner be installed in a 68 cuda fastback without removing front and rear glass.I definetly do not want to remove rear glass because of difficulty and tuff to get someone to do while front window is out of car in body shop.
yes. You have to have a rubber windshield gasket that is pliable enough to lift and tuck the headliner up inside and get the teeth to grab on. Most car. Just have to give it some business.
Take a dull putty knife and lift it up now to see the teeth that hook the headliner.
