Can You Help Identify These?
Valkman
NC
I putting a car back together that was was apart when I got it so I'm putting pieces of the puzzleback together and need some help?
Can anyone tell where these interior screws go?
hmm #6 looks like a dash bezel screw , my 66 has 4 of then holding the speedo bezel in but look to be a little shorter than yours. might work for your year of car.
#2 looks like (again going off of a 66 dart) screw that holds on the top chrome trim on the door that my door panel slide into.
#1 looks like the same screws that I used to put the front kick panels on and I think the inner sill plates for the carpet hold down piece
#3 looks like outer sill plate screws
can't help on the rest. I've seen #5 somewhere but can't remember where dangit!
#3 is used at a variety of locations including sun visors & interior rear view mirror #6 is for the dash cluster #4 is as mentioned A-Pillar #1 also was used at different locations i can't tell exactly how large the washer is but that type is used to hold the windshield fluid tank out under the hood and some dash structure locations inc the ground wire #5 looks like the one that is used for the rear sill plate extensions #2 is used for the weatherstrip end caps on your doors
#3 is used at a variety of locations including sun visors & interior rear view mirror #6 is for the dash cluster #4 is as mentioned A-Pillar #1 also was used at different locations i can't tell exactly how large the washer is but that type is used to hold the windshield fluid tank out under the hood and some dash structure locations #5 looks like the one that is used for the rear sill plate extensions #2 is used for the weatherstrip end caps on your doors
Question answered...
