Can you help me repair this latch post?
Mopar Body and Trim
  1. Bill Crowell
    Bill Crowell Well-Known Member
    760
    253
    Oct 16, 2007
    Diamond Springs, CA
    Local Time:
    6:24 AM
    Attached is a picture of the driver's door latch post on my '77 B200 Sportsman SE, which I have owned since new and is in pretty good shape. The latch post is composed of the inner post, a thin plastic tube over the inner post, and a thin wall steel tube as the outer part of the post. My inner plastic tube has broken and fallen out, so outer steel tube flops around and the latch won't work properly. Would any of you guys know how to repair this latch post, or do I need to find a different one? Thanks a lot.
  2. moparmat2000
    moparmat2000 FABO Gold Member FABO Gold Member
    11,804
    2330
    May 13, 2010
    Grand Tetons
    Local Time:
    8:24 AM
    Buy a replacement
    • Agree Agree x 1
    • KosmicKuda
      KosmicKuda FABO Gold Member FABO Gold Member
      1,518
      367
      Jan 15, 2011
      N Ohio
      Local Time:
      9:24 AM
      Get one from a passenger door, less use=less wear.
      • Like Like x 3
      • moparmat2000
        11,804
        2330
        May 13, 2010
        Grand Tetons
        Local Time:
        8:24 AM
        Arent A body ones the same?
      • famous bob
        famous bob mopar misfit
        11,797
        3053
        Aug 14, 2011
        okla
        Local Time:
        8:24 AM
        I made a bronze bushing for mine , but ended up w/ a pair from ebay. I still have one some where if ur interested.
        • Like Like x 1
        • jazak5
          jazak5 Well-Known Member
          491
          138
          Aug 6, 2015
          NY
          Local Time:
          9:24 AM
          NAPA enter door striker bolt many show up
        • sireland67
          sireland67 Well-Known Member
          7,776
          1800
          Oct 27, 2010
          WV
          Local Time:
          9:24 AM
          I am pretty sure it is the same latch as a A,B or E body, probably most 70's trucks. They are a pretty common wear item when the hinges start wearing out.
          Honestly, I would be more concerned with the hinge wear, it needs fixed before changing striker pin.
        • moparmat2000
          11,804
          2330
          May 13, 2010
          Grand Tetons
          Local Time:
          8:24 AM
          Van lower hinges were very similar to 67-76 A body and 66-70 B body. However if you can find a late 90s ram van they use thicker pins and bronse bushings but otherwise are the same. Replace the upper and lower hinges with those newer redesigned hinges along with a dorman pin and bushing kit. Thread on them is still SAE, and not metric
        • RustyRatRod
          RustyRatRod 30 Degrees Outta Whack FABO Gold Member
          49,145
          15333
          Jun 7, 2010
          Georgia
          Local Time:
          9:24 AM
          Bill, before you go removing the old one, mark around it first. That way you can put the new one right back in the same place and probably get it right the first time.
        • Bill Crowell
          760
          253
          Oct 16, 2007
          Diamond Springs, CA
          Local Time:
          6:24 AM
          Thanks a lot for all the advice, guys. I'll do what you suggest.
        • famous bob
          11,797
          3053
          Aug 14, 2011
          okla
          Local Time:
          8:24 AM
          Guess ur not interested in a good stocker, was going to give it to you ----------
        • Bill Crowell
          760
          253
          Oct 16, 2007
          Diamond Springs, CA
          Local Time:
          6:24 AM
          Heck yeah, I'm interested, Bob. I just meant that I would follow everyone's advice to check the hinges, to see if maybe they had caused undue strain on the striker post. But yes, I am in great need of a replacement because it is different from other Chrysler products and I can't find one!
