Can you ID these brakes?
Suregrip391
Wheatfield, NY
Not the best of pics but...I was told 73-76 A-body, large bolt pattern but they just dont look right,I could be wrong??....
Thats exactly what they look like. The bolt through LBJs are A body, and the rotors look to be the 10.87" diam. OEM rotors. Looks like plenty of meat on them to cut them as well. MIN. Thickness. .940" after final machining.
Sorry, he did not send me any pictures of the calipers..Just what you see here. The seller also told me that these rotors and calipers were only 8 months old, taken off a show car and replaced with an aftermarket setup....*Yikes* Looks a bit older then that to me..... :angry7:
They are BBP.
They look like A bodies to me. The FMJ knuckles look similar and are slightly taller. The upper control arms look like A's too. Only real way to tell is to get some measurements.
The spindles will likely work on an A, or your B.
