Cancel Cam 70 Dodge Dart
Russell Credle
New Member
Tennessee
I have a 70 Dodge Dart Swinger with the original rim blow steering wheel. I replaced the turn signal assembly when I did a full restoration but cannot figure out the cancel mechanism. There was not a cancel cam in the steering wheel when I purchased the car. Can anyone help? Russell Credle 615-476-3542
We might need a photo of the back side of the steering wheel, and the turn signal switch as it's mounted in the column. The cancel system needs the plastic fingers in the switch, and a metal ring with a post on the steering wheel.
Thank you for the reply, attached are the pics. Thank you
