SirDan
So I was out beating on my car about 2 months ago and it felt down on power, got it home and it was idling slightly rougher. Then i noticed I had a knocking noise from 1800 rpm and up. I have also noticed when it gets warm the passenger cylinder bank smokes out the exhaust. A compression test had the lowest cylinder at 108 and the highest at 120. Which is about the same as when i tested it a year ago. I checked for vacuum leaks and there is none, checked timing and it is good. distributor advance is free and smooth.
Not too sure what is really wrong here. If it just knocked id say i had a rod knock, but it smokes and feels a bit down on power. Then i think maybe its a head gasket leak but the compression test seemed OK.
any ideas?:dontknow:
