Can't find correct water neck
MrJLR
Built, not bought
Menifee, California
Can someone help me find a darn water neck for a LA 318?
I've got 3 different ones from Summit and the bolt holes are too far apart on all of the....thermostat is wrong too????? Should be SIMPLE.....even called Summit and told them what I have and they send the wrong one...
Here is my old standard Original
And the thermostat they sent me doesn't fit up inside my old water neck either.....
I am blown away this is such a PITA......
JEFF
Let me poke around in my stash ... I've seen quite a few. The problem is I don't remember if they're mine, or customers' parts. :-D
Than I s....I can't understand why this is so hard.....and the thermostat too...?
Do i have some rare 318 or something? Lol....
Jeff
Jeff
Nothing rare Jeff. Most small blocks had the straight t stat housing. The earlier cars (66 for sure) had straight cast iron housings.
Geez, last time I remember buying a cast one for my 318 streetmaster I bought it like at AutoZone as a stock replacement part..
Ya...I went by NAPA and Pep boy's. ...no dice....
Like I said, I'm stunned this is so hard to find.
I don't care if it's chrome or steel or aluminum. ..just needs to fit!
Jeff
Stay away from the aluminums. They try to seal with a o ring and usually leak.
Actually back then I was using Knecht's Auto Parts. But it was just the average run-of-the-mill Auto Part place. Maybe check and see are they out of stock or that that particular story just doesn't have one?
JEFF
That is a 1979 and newer thermostat housing. It uses a smaller t-stat, the same one SBC's use.
Here's a link to the correct housing. https://www.summitracing.com/parts/fss-84909/applications
Thanks...I'll Google them
Jeff
But I doubt your factory cast intake is a '74? You need the correct one for your intake, not engine. Also, there are only 2 sizes for the LA mopars, if I recall correctly
I believe this is true. Believe it or not I got a cast IRON one at O'Reallys. I had an Ed intake with DUAL stat bolt patterns, and a leak problem. I forget if I went with the wide or narrow "bolt pattern."
78 and older uses the large thermostat/housing and 79 and newer uses the small thermostat/housing. They changed it when they went with the newer style AC compressor. The later outlet is offset towards the drivers side also. Magnums use the small t-stat also but I'm not sure if the bolt pattern changed or not.
Here is an early style Torker compared to a later Torker II intake.
M130670772
Wow....thanks guys!
I had no idea they changed in 1979....!
And it seems my intake must be a '79 or newer then.....this explains a LOT!
I tried to Google my intake casting numbers but came up empty....now I know a little more.
Thanks again. ....
Jeff
If you are looking for the one that would had been on there factory in 1974 -Tony's parts is repopping new ones with and without the casting marks and part numbers just like Chrysler made them. Like $40.00 if you interested.
Joe
Joe
Thanks but it turns out that the one I need is 1979 or newer...
Jeff
