I'm building a full chassis for my 69 and adapting Viper suspension to it. I've got a bunch of Viper stuff already, just need the suspension assembly's for each corner. I'm new to all the fab stuff myself but am taking my time, asking a lot of questions and learning as I go. If you wanted to adapt those components I think it would be easier than my Viper stuff. Reason being is there is alot of information regarding the location of suspension pickup points. From there, it's building brackets to adapt control arms. Would definitely have to do some chassis reinforcement for the transaxle but it's doable. Since you already have it, you should do some checking into it. Sign up on Lat-g or pro-touring and start asking questions. A lot of guys have done, not to Darts of course, both pro-builders and garage builders. Doesn't seem to be moving so it's worth researching anyway. You would likely have to change the setup of your backseat and may end up with a setup similar to the newer GTO's with dual buckets in the rear. I am likely picking up a GTO rear seat for my project. Can't hurt to research it all. Alot of info on PT and Lat-g...
