4404spd
Im working on my sons 1970 340 Dart and about to pull my hair out.
First off its a 340 thats 30 over 10:2:1 compression J heads cut out to 202 valves, Mopar Performance cam 280/280 @50 238/238 centerline 110 and lift is 474/474, Wieand 8007 dual plane intake and Eldelbrock 1406 Carb.
The problem is the idle. It won't idle down. I found out the ported side of the carb is pulling vacuum at a idle. If I pull the vacuum advance off it will idle down. This problem is the same with 3 1406 Eddy carbs i tried. I tried a square flange spacer and its the same. I put the weakest metering springs in and the largest rods 1407#. The cam is not radical but with the centerline its only pulling about 9" of vacuum. Is this intake junk or what...
