[SOLD] Carb studs ,nuts, washers
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
Set of 4 carb studs ,nuts, washers used. $6.00 shipping included to the lower 48. From Plant City Fl. 33565
If the nut on those bolts/studs are the ones that have the small wrench size I'll take them. It should be a 5/16 stud with a 1/2" (wrench size) nut but they also make the same 5/16" fine thread nut with a 7/16" wrench size. If you have the 7/16" wrench size nut I'll buy the studs and nuts.
Thanks,
Treblig
