I discovered my carburetor is slightly swiveling on it's mount, creating a vacuum leak, rough idle and car running rough. I plan to rebuild the carb next Spring but....
Is the carb screwed to the mount from the inside? Can I remove the carb to access the bolts, tighten them, and put the carb back on? Is this how the carb is connected to the base that is bolted to the intake?
I can physically slightly swivel the carb while the car is running. When I go one way, car runs fine, when I swivel the other way, the car runs rough.
I will garage the car in about a month for the winter.
It's a '66 Barracuda
Thanks!
Thanks!
