crazy 340
Who use them and why
Can it help me
Yesterdays was pretty hot close to 30*
When for a ride with the duster and the engine began to act some kind of weird
Like it was to lean and few second later to rich and the accelerator pump
Wasn't working at all or should I say not like it work normally
Stop for shopping with the wife it took about 1 hour and we took the road again
After maybe 3/4 of hour it did the same so when I arrived at home I took a look
Didn't see nothing wrong took off the air filter (engine still running) I heat the gas pedal
A few time and the gas was going out by the vent tube
So I tough the float level was to high but everything was find
I'd remove the front bowl to see if something was wrong but ounce
Again every thing was find
Could it be to much hot air under the hood causing this
The engine was 195* but with second speed of the fan on (ferd contour setup)
Today Id restart the engine and everything was find but its aloe cooler today
Any idea???
Thanks Bob
Can it help me
Any idea???
Thanks Bob
