pyrojim
So, motor is finished and running, everything seems to be good but I'm fighting the kickdown linkage. Doesn't run in plane and the throttle cable doesn't quite reach. The car originally was set with a 360 Magnum crate, M1 mopar single plane manifold and a holley 750 with a 1" carburator spacer. The motor was rebuilt with a rpm air gap and a Holley 650. Do I really need the spacer? Does it help me in any noticeable way. This is a street car, probably won't see any track time and 6000 to 6500 max RPM. Any input?
Thanks.
Jim
Thanks.
Jim
