I need some opinions on what size cab to run on my combo. This is just a weekend cruiser with an occasional beating to clean it out. I want a double pumper, should I go 650 or 700 or 750 and why?
67 Dart
340 ci
Edelbrock 60779 heads
Edelbrock Air Gap intake
Hughes engines roller rockers
Lunati 268 cam
Hydraulic Flat Tappet. High performance street cam likes 2400 RPM stall, 700 CFM carb, dual plane intake and headers. Makes unequaled power to 6200 RPM with proper valve springs. Strong cam with great street manners for crate motor.
•Advertised Duration (Int/Exh): 268/276
•Duration @ .050 (Int/Exh): 226/234
•Gross Valve Lift (Int/Exh): .494/.513
•LSA/ICL: 110/106
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 1800-6200
Part Number: 10200703
Previous Part Number: 60403
9.5:1ish compression
4 speed
3.91 gears ( will probably go 3.55 later )
67 Dart
340 ci
Lunati 268 cam
•LSA/ICL: 110/106
4 speed
