[SOLD] carlisle parts list
bnichols
Endicott NY
here is a list of parts i am taking to carlisle spaces m68-70
black f body front door panels $50.00
72 340 intake $50.00
mopar perf dual plane aluminum intake 100.00
70 small block oil pan $25.00
70 valve covers $25.00
14x6 lbp wheel $10.00
tuff wheel horn switch with mounting screws $10.00
tuff wheel adapter cans 2 of them $75.00 each
original tuff wheel tight grip nice shape $250.00
dales cuda shop tuff wheel repro $150.00
1970 340 air cleaner $350
am 318 four barrell orange pie tin $20.00
windage tray with bolts $50.00
1.6 harland sharp magnum roller rockers $200.00
new green wheel bearings 8 3/4 $50.00
a body am/fm radio $100.00
rt angle oil filter adapters 1 new aluminum $40.00
one cast iron used $25.00
mp pushrods when installing magnum heads onto la block not made anymore $50.00
pair of magnum heads off of a 300 horse crate motor 1/2 dozen passes on them $300.00
15 small bolt rh threads 10 front 5 rear new am $10.00
mp small block dizzy $25.00
small block dizzy with pertronix installed $20.00
nos wide a-body rocker moldings with clips $100.00
70 sb hose clamps with ac 2 sets $10.00 each
factory magnum rocker arms etc 6 1/2 dozen passes on them like new and head bolts $20
upper police car blue hose used lower and blue heater hoses $25.00
am shift light with dial $10.00
left over msd dizzy springs and bushings $5.00
used f-body door edge guards $5.00
magnum valve cover gaskets $10.00
oil filter adapter gaskets mp part $10.00
70 duster full wheel covers $30.00
904 24-2800 stahl converter $200.00
70 340 kickdown linkage and throttle cable $75.00
67-71? fuel filler necks $10.00 each
Is the AM/FM radio a thumbwheel radio? If so, I will take it. Do your Volare door panels have the chrome on them?
Thanks,
Craig
Thanks,
Craig
sorry not a thumbwheel round knobs
what chrome trim are you talking about?? these are solid black off of a 78 supercoupe
I will take the 70 340 kickdown linkage and throttle cable PM sent
here is a list of parts i am taking to carlisle spaces m58-60
guys my bad spaces are M58-60 all prices are obro just ask you never know!!
