Carter AFB - 1966 273 4bbl 4-speed M/T
robodhran
Wettingen
I do have a 1966 Barracuda 4-speed manual with the HiPo Engine and the 4bbl carburetor (no CAP)
This carb. has the tag#4120 and belonged to a automatic transmission-assembly (A/T) from wich I took it off. It's rebuilt.
--> Correct would be a Carter AFB with tag#4119 for manual transmission (M/T). (...If I only had one... :rolleyes:)
Does anyone know the difference of M/T and A/T?
It doesn't take full throttle (f.e. in 2nd gear). If I push the pedal slowly, there is no problem.
Before checking ignition and more, I am trying to figure out the difference in carbs.
Thanks, Robert
I think the 4120 has a lever for the kick down linkage for automatics.
I'm not an expert but typically the manual carbs had a little different idle speed setting otherwise I wouldn't expect too much to be different between the two.
If you are talking about the engine not responding to a WOT stab I'm thinking the accelerator pump is not working.
Thanks for the hint... didn't think about acceleration pump.
I swapped the linkage more or less...
