TylerW
Hey guys:
I'm in the middle of overhauling a '68 AVS, and I discovered a couple problems. First it appears to have the wrong primary jets in it, in this case regular AFB style 386 jets, where this carb should have the tall 398 primary jets for use with the 3-stage rods.
What's interesting is that the rear jets appear to be the correct 489 jets, but they are tall as well. I've read conflicting info about whether tall jets should be in the front or rear, so my question is, which answer is the RIGHT answer?
Second issue is that the pump side primary rod got bent at some point and is now almost worn in two. I know about converting to AFB stuff but right now that is a last resort. This is a Carter 4401S BTW. Thanks.
