71Duster
What can you guys tell me about an 833 with the following stamps.
Case 99129, Tailshaft C99126, Sidecover C99386,
retainer 094796. serial nuber on case 2B456493.
Ball and detent style sidecover, 23 Spline
Looking to buy it for a 727 to 4 speed swap in my 71 340 Duster. Also whats a decent price?
The seller gave me he following info
"Internally the syncros show minimal wear with good gap between the synchro and cone in all gears. All dogs on all the gears are excellent (transmission will not slip out of gear). Shift forks show minimal wear
Countershaft shim is well within specification, there is one small chip on the outside edge of
the countershaft 4th gear. This is of no concern since it is not on the leading edge (someone missed a shift). Front and rear bearings show no wear, all bolt holes including transmission mounts are good, no helicoils. Front bearing retainer shows no wear. The front of the case has letters ACE stamped in it"
