What years did they make cast cranks? I ask because I have a 1969 225 that has a cast crank, narrow bearing journal. I was under the presumption that all 60-75 cranks were forged and 76-84 were cast but I must be wrong.
Dan, do you have any literature with all that decoding information?E can indicate a '69 engine if it is the first character in the stamping on a passenger car engine. In other positions, it indicates other things. For example, an E later in the stamping like this indicates a cast crankshaft.
225 is self-explanatory
T is either truck engine or Trenton engine plant (depending on who did the stamping, when)
2 24 means the engine was built on 24 February.
But we don't know what year, because the wild card here is that "1" at the start. How sure are you it's not a poorly-stamped or otherwise distorted something-other-than-1?
Keep in mind that engine stamping errors and foulups are very common.
What other numbers do you find elsewhere on the block? What numbers are cast into the manifold side of the block?
Me too. I'm out of knowledge, then. As much as the passcar engine stampings differed from what the books said they were supposed to be in terms of format, the truck blocks seem to be even more diverse.It seems very much like a "1" to me
Used to. It couldn't come with me in 2019.Dan, do you have any literature with all that decoding information?
Sad. Know where one might acquire that info?Used to. It couldn't come with me in 2019.
