plum crazy dart
Changing the radiator in 74' /6 225. the coolant controlled exhaust gas recirculation valve (ccegr) broke off trying to get out of old radiator. The hole where it goes into rad has some type of plug in it. Wouldn't think you want coolant going into vac system. Problem is the new rad the hole is open to the tank. Is there some type of plug that goes in the hole to stop the coolant. Do I really even need the ccegr valve? thanks:?
anyone?
anyone?
