center link question
FJ5
chickasha, Ok
Is the center link the same on a 70 dart swinger /6 and V8 or are they different?
Same piece, don't be fooled by people trying to sell a V8 67-72 centerlink...
did you read the year? 62-66 early A cars have a different center link, after that they are the same. 67-72, then 73-76, Lawrence
First gen' A-body had 2 different center links. 67 through 72 are all the same,
Then they changed in how the arms are attached so 73 thru 76 all the same.
on my 71 the centerlink did rub the pan.... not no more was cut down in milling machine then I smoothed it out... you can see where it was cut down on each inner side of the castle nuts. shed some weight in process :0)
Why do you ask? What are you doing to the car.
I had a center link issue when putting my 440 in my duster. YES they CAN be different.
Mine was
