Change over to Disc Question
cybrtygr32
1967 Ratfish Fastback
Alabama
Okay, I have the rotors from a 73 Duster (machined down to fit my Bullitt Wheels) and the upper and lower control arms, spindles, etc. These will go on my 67 fastback cuda. Can i get away with just changing the upper arm now and put the new Duster lower joint in along with the new spindle and Duster upper joint? Didn't want to disturb the lower control arm and torsion bars just yet. I know, I should do it all at once. And probably will.
Thanks
Mike
when i swapped to disc on my 65 cuda i used a 73 disc setup and never swapped out the lower control arm just the upper and spindle and disc parts is all you need
