Yunick13
2 Time FABO NASCAR champ 2023 FABO NHRA champ
Cheap way would be to just put bearings in it. The smart way would be to pull it and drop in a crate engine with a warranty.
But where is the fun in that?Cheap way would be to just put bearings in it. The smart way would be to pull it and drop in a crate engine with a warranty.
So I have a 96 360 magnum that got some ported heads that were also a few cc smaller bumping up the squeeze... so after a few thousand it sounds like a slight rod knock 'pass side'. Its faint.... so I'm thinking about pulling the oil pan and changing A. The rod bearings and B. The oil pump. It's a crap shoot I know but the odds are slightly in favor I believe... but I could be wrong. Have to see what the journal looks like.
Should I or should I just build another..
What say you guys?
Mic the journal to see how far out of round it is. Maybe try going with a few thousandths undersize bearing or just the top shells of an undersize set and regular size shells in the bottom to tighten the clearance marginally.
MP being killed off by Globalist Stellantis, is there an aftermarket unit you can use?It comes n goes.
It's gone at the moment.
What I'd really really really like...
Is an mp computer.
Those mthrfkrs programmed the stock magnums to retard under WOT.. They cruise at 36-38 advance and drop to 20 btdc at wot.
That's where power and mileage are lost on them.
You can tune them now with HP tuners.It comes n goes.
Is an mp computer.
Buy a tune after you buy a tuner?You can tune them now with HP tuners.
Nope. Buy the software and build a tune. Is yours obd1? I need to check if hp tuners can support obd1 jtecBuy a tune after you buy a tuner?
'96 obd2Nope. Buy the software and build a tune. Is yours obd1? I need to check if hp tuners can support obd1 jtec
Is the crank Virgin, or cutSo I have a 96 360 magnum that got some ported heads that were also a few cc smaller bumping up the squeeze... so after a few thousand it sounds like a slight rod knock 'pass side'. Its faint.... so I'm thinking about pulling the oil pan and changing A. The rod bearings and B. The oil pump. It's a crap shoot I know but the odds are slightly in favor I believe... but I could be wrong. Have to see what the journal looks like.
What say you guys?
