64physhy
I made a custom cluster of Autometer Gauges for my duster, and now there's no power to anything. The volt meter is hooked up, so it's not that. I really haven't looked too deep into it, been busy and lazy. Any ideas?
Power used to pass from the alternator, into the cabin, through the amp gauge (where 12volt power is spliced off) and back out the cabin to the starter relay where it provided charging to the battery. If you break the loop, then you are losing your 12 volt power source. The ideal with removing the amp gauge is to connect the two wires (red and black) that ran to the amp gauge originally. After connecting those, they are now you constant 12 volt source. A splice comes off of that for the fuse panel, keyed sources, etc.
If you have already done that and you still don't have power, check the fuseable link. You may have accidently shorted it out.
a volt meter cant use the same 2 wires that a amp gauge uses. check the fusible link at the firewall.
Thanks!! I'll check it out tomorrow (if I can move my legs). Do you think I screwed anything up, like the gauge?
