Changed out the shifter in my 64
64 AAR Valiant
ODD DUCK
K PAX Pennsylvania
Needs a few minor tweaks.
Next is putting the factory wheel back on.
Looks like you got it right where I would want it, a small bend towards the driver and you got it perfect in height, good Job :thumbsup:
Shifter looks great!
On your aftermarket steering wheel, did you use a Grant adapter? I've seen comments that they may not fit properly.
It came with the car. It seems to fit and work fine.
Just to small with manual steering.
Have power set up just not sure if I want to convert.
You want the wheel? Pm me and I will send it to you after Install the original.
Be about a month or so till I get to it.
