airwoofer
Drivetrain limit explorer
In anticipation of putting my big block into the drag Demon I am looking into getting a Dana 60 setup so it can be a bolt-in replacement. The 8 3/4 is narrowed to about 48" flange to flange and has the ladder bar brackets. I have a Dana lined up but it needs to be narrowed to fit and have a set of ladder bar brackets put on. I would like to be able to use my 35 spline Moser axles that are in the 8 3/4 in the Dana. Both rear ends have spools.
Is the side to side width of a Dana spool the same as the 8 3/4 spool? Anybody know?
