I have a 1974 Duster that I rewired with a Bare Bonz Ron Francis wiring kit. I can not get the alternator to charge. I have the alternator tested and it is working properly. I am on my second voltage regulator and am still having the same problem.
The alterntor has the main feed wire going to the starter solenoid. There is field wire going to alternator from the regulator plug which is connected to the A side of the regulator. Then there is a jumper wire between the A and S on the plug. On the regulator plug there is a wire that connects the F side to the fuse box. There is a ground on the regulator to a grounding strip. There is a ground on the second filed terminal going to a grounding strip.
This is what I have so far I am not sure what it all means but was hoping somone could help.
Here is the info with the key off
Battery: 12.9V
Main Power at Alternator: 12.9V
Field 1: 0v
Field 2 (Ground): 0V
Fuse Box: 0V
Regulator (A,S,F): 0V
Here is the info with the Key On and or Running:
Battery: 12.3V
Main Power at Alternator: 12.3V
Field 1: 10.4v
Field 2 (Ground): .2V
Fuse Box: 12.2V
Regulator: A and S: 12.0V
F: 10.4V
PLEASE HELP!!!!!!!!!!
Battery: 12.9V
Field 1: 0v
Fuse Box: 0V
Battery: 12.3V
Field 1: 10.4v
Fuse Box: 12.2V
F: 10.4V
