PolarBear
I have a charging problem and I'm not sure how to diagnose it.
During normal daylight driving conditions, the ammeter guage in my 65 Barracuda indicates the battery charging rate is "stable" - that is, the needle is centered between the charge and discharge regions. I can drive all day long and the battery stays charged.
When I use the turns signals, however, the needle mimics the blinking turn signals - simultaneously dropping into the discharge region then rebounding to the "stable" position - tink, tink, tink, tink, etc., etc.......
And when I turn the headlights on, the needle noticeably drops - and stays - in the discharge region. If I continue to drive with the headlights on, the battery will gradually run down - after a couple of hours, it's virtually depleted.
I think the ammeter guage is working correctly. I have installed a new alternator, alternator belt, regulator, and headlight switch - all of which have improved the situation a bit, but not solved it.
What is causing this drain? Is it a wiring issue?
