[FOR SALE] Charging system bulkhead wire around
crackedback
Charge system bulkhead wire around. The idea is to remove the bulkhead connectors and resistance in the circuit from the charging wires. I have two set ups available. One is 6ga wire, the other is an 8ga wire with a 12ga fusible link. The 8ga wiring solution would be OK for alternators up to about 90 amps. The 6ga would be OK to about 120 amps in most situations. Most of the time the alternator is not providing maximum output.
6ga wire around
8ga wire around
I use as much US sourced wire as possible. It's getting tougher to find US sourced fusible link.
Wire set ups are $30-40 depending on length + shipping from Indio, CA
I do provide discounts for customer loyalty and multiple items purchased at same time.
PM here or email to robule1 at yahoo dot com
Thanks for the ad space.
Rob
using anything over a 75 amp the people should also use a shunt on the back of the alt gage just incase the alt does go to full output after rewiring the alt the gage will be the week point!!
