j par
So I'm trying to wrap my head around this cheap aftermarket 20 circuit wiring kit..
I have a power supply that I can use for testing wires and so forth. I'm thinking there's two real sources for power one being what looks like one that goes to the battery solenoid and one that looks like it goes to the alternator. Both of which I believe are the power sources for the fuse box... I got wires a dangling everywhere LOL.. anyways I was thinking if I hook the positive of the power supply to the positive battery or alternator and my test light to the negative of the power supply I could touch my test light to certain wires and test each circuit and also test the blinkers and mainly the ignition switch is the one that there's a little iffy. Just wanted to test things before I actually hook them up and start splicing into too many wires...
I was kind of hoping to set up my steering column and run juice through it so I can test to see if the ignition wires are working the way they should and if they're lighting up the fuse box the way it should..???..
I figured as long as I didn't use the frame or anything as a ground yet that the ground would just be the completion of my test light?...
