So adding shims under the big bearing should move it toward the center..is that what I should try next?That looks to me like the contact pattern is much to shallow on the ring gear. I would not run it like that.
Yup.So adding shims under the big bearing should move it toward the center..is that what I should try next?
YupSo adding shims under the big bearing should move it toward the center..is that what I should try next?
