Mopar92
Today was the first day shaking down my Duster build. I put a mini starter in it from the parts house. I have a 440 source flywheel on this 360 LA. Yeah I put the La weight on it. Anyway, it fires it up nice and fast. Sadly, it sounds like those 80's GM starters. Nice mismeshed sound while starting. It sits very flush up in the bell housing. It retracts the bendix nice as well.... But while cranking it sounds like an 88 Chevy truck... Ugh. So the starter is seated all the way and aligned well. What's causing this? Starter gear too close to the flywheel? Too far away? Resting and looking up through the bottom dust cover it seems the gear is close. Looks like the bendix gear is .020" off the flywheel but it doesn't grind once you let off the starter. Never had this issue with a mini starter. Thanks.
