ddart cart
Good day, Mopar people.
The china gap has LA, and Magnum bolt holes. The magnum intake bolts seem a little weak, and slim. The torque spec is 23-25 ft/lbs. No ac, no problem.
Is the torque spec identical for aluminum and steel manifold, in this application?
I got a few bolts to tighten within spec, but the other few approach 20ft/lbs, then turn some more, and feels like a bolt about to snap. After being terrified by that, the bolts got turned more without breaking, thankfully, but they still turn more as I approach 20ft/lbs without showing a higher torque. I stopped before I cause a problem.
My other question is the press plugs for the unused bolt holes. I had to hammer the crap out of the ones I got in, but the 4 around the carb plenum are not hammerable. Are these plugs necessary, and if so is there an easy alternative?
