Tire shop over torqued lug nuts (1969 Dart). Should I redo it?
I'm sorry, I linked the wrong dang one. It's this one. Trust me. This is something you can do. Just go really slow with light pressure. A very little bit at the time and check between cuts. Don't cut very long at all. All you're looking for is a clean, unifom seat. You're not trying to enlarge anything.
Thanks. :-)
Here's an image of one of the wheels. I seem to have got that working now. I don't know how easy it is to see the condition of the lug seats though.
Yeah, my mother is the original owner of this car. It's unmodified. It "only" has 158K on the original engine (225 Slant 6). I really would not be suprised if the lug nuts are from 1969.
Very likely. But they could still be in good shape were they not abused. No fault of yours.
Yeah, I can only imagine what was done to them over the years. I only started working on the car myself recently.
Am I right that 7/16-20 is the correct thread size for the lug nuts?
is it just me or do the nuts and wheel seats look galled
Seen that a bazillion times in the shop, it happens over time, even if they're not grossly over-torqued. It was common to have them on cars & trucks to come off dragging like a torque-prevailing nut, the wear & repeated torquing causes the nuts to become swedged, to the point they gall & pull threads coming off. Sometimes I'd grind the ends of the taper off, light lube the studs & run straight lugnuts on backwards, many of them worked OK after that. Otherwise, it turned into chasing/fixing threads &/or replacing stuff.
The taper dressing of the rim seat Rusty was talking about is very helpful here, old 60° seats in alum. rims need love too, they gall & get rough over time for sure.
People rarely think of it but it helps to lubricate the lug nut seats in the wheels too. It will not affect how they lock down when torqued.
