City Water Filtering Setup
George, we’re roughly 5 miles NE of the Elk River landfill. Thankfully we’re upwind of it, but we are concerned about our water quality, naturally. We use those same 5 micron filters as the third stage of filtration:
Downstream (and not shown) is another 5 micron filter before the softener, and then a “final” UV stage before it gets sent around the house. In the kitchen we have an RO system on the cold water.
Since we replaced our well pump I’ve had our water tested three times by different labs (will be taking samples for the 4th this weekend), and we’ve come up clean on each of ‘em.
Oh, and absolutely no taste or flavor to our water from any of the taps.
Jim, going to be a plumber when you retire?
:rofl:
I’ll be a retired Pipefitter, and to be perfectly honest, once I get the new furnace installed in the shed/shop, and change out the condensing unit at my folks place, I’m hanging it up!
Lordy. All we have is ONE filter on our well but it tastes just fine. lol
We had an issue with our well this past summer, and considering the damage done, not only real but also theoretical, we decided to take no chances with our drinking water and we went all out.
Truth is, I’m thinking of adding even more water treatment in the form of chlorine injection. Still on the fence on this one though.
I don't want chlorine anywhere near our water. I do need a good bit of updates on the plumbing, though. Including moving a water heater...and I ain't no plumber. lol
I’m EXTREMELY concerned about chlorine as well, and we do have a UV light to kill any/all bacteria that may be in our water, but I also like to have redundancies in case of failure.
Still giving it some thought, though….
Wish you were closer so I could help you with the water heater! That’s easy-peasy stuff, as far as I’m concerned.
Well, it's gonna be a little complex. It's behind a wall in our master closet and I want to build a cabinet on the back porch and relocate it there so we (Kitty) can have more closet space. As if she needs more. I've replaced the water heater before. That's in my wheelhouse. But relocating it is a bit beyond me.
The city water here is okay, except it has an extremely high calcium content. I've talked to the city multiple times and was basically told to live with it.
My water is filtered but now my wife is concerned about microplastics. I believe she said the average American consumes the equivalent of a credit card a week.
Chlorine is used as a disinfectant residual.
In a municipal application a residual(Chlorine or Chloramines) is a legal requirement. This helps to ensure nothing in the distribution system will start to grow, after being treated.
UV alters the bacteria DNA, it doesn't kill them. While UV is awesome, turbidity(small particles) MAY shield harmful bac-t from being treated.
What the UV may do is lessen the amount of CL2 needed.
I will take CL2 all day every day. Its been used for over a century.
Redundancy is a good thing with H2O.
I remember you posting pics when all that was going on. You've got a nice place there. Is the neighborhood burdened by an HOA? If not, I'd be tempted to put up a shop plenty big enough to work in, but not overrun the lot.
No HOA fortunately, own the property 100%. Big factor in buying the place was that I would own the lot.
I sure like having that big open useful space.
My neighbor just put up a 24 x 24 x 12 steel building, nice building. But now it has plugged of his access to his back yard.
Name your poison, I like the openness and freedom of access for now. Shade awnings are providing a place to get some work done out of the hot sun and rains in this favorable climate.
Those steel buildings get really hot inside too.
Yeah, we were having an algae issue in our filter since it's a clear filter housing, so I taped over it with black electrical tap and that fixed dat chit. lol
Then yall need bigger back yards. lol
We have Sulphur water here, HOA, about 17 homes on the well. Use chlorine to kill the Sulphur bacteria. You don't want to drink water out of a hose here! I have Reverse Osmosis system in the house for drinking water, and and car cooling system. When I was a kid growing up on a farm in Southern Minnesota, we had a deep well, about 360 feet. Best spring water I ever drank.
Ours is about 340. It's sho nuff good, too.
I have a water deionizer in my shop. I use it to rinse vehicles after washing, battery water, cooling systems, irons, etc. It removes hardness minerals in the water, similar to distilled water. You just blow off the car after washing or take it for a quick spin. Leaves no water spots, had it for years, got it when I was in the battery business. Amazon sells them and the replacement cartridges, they last a long time for me and it has a light that indicates when the cartridge needs replacement. The reel and hose are from Harbor Freight.
Ours has that too, but rather quickly it got a moldy musty smell and taste so we stopped using it. Even with a new filter it was the same way.
I ran into this issue as well. I replaced the water supply line ( white plastic) from the house to the fridge and it went away. Copper is even better…
Also after adding a whole house water filter, 3/4 inch that cost about $6 each and lasts for 3-6 months) I removed the fridge filter as if I was doing to replace it and left it off.. fridge still delivers water to the ice maker…
Good idea swapping plastic with copper. Plastic harbors more **** and more susceptible to leaching.
For well water it pays to get a raw water sample tested to see what is in it. Fluoride is a natural mineral that is found in raw water supplies.
Filters can be easily/quickly plugged by poor raw water. Knowing what's in it helps you pick the right filter.
